im talking to Josh btw, coz most of you probably won't know what thread im on about...
I’d rather not comment. Neil changed the Logo to use for TK, Aaron used the same one Neil had changed. He could have atleast changed something.
yea i know, i'd posted heaps of stuff in there about it...but yea....its all been removed...i don't know why....obviously "off topic" however i've seen things a lot more off topic let go.
SPAM!
How is everyone?
Just a quick question
Why is there so much junk on the forumns atm?...
Im bored shitless here, the only thing i can be entertained by is meaningless questions people ask for opinions, these were posted on topic with no real thought and all they get from posting these is a genuine reason, after that, the case is closed, everyones agreeing, or agreeing to dissagre, then theres nothing left to say.
I guess im having a little bitch about this because i can only relate to these types of topics because i do not have a car, nor the knowledge to help people out with thier car issue topics.
:D thats my two cents *breaths out happily*
Any one want some pie? :)
Edited by ze_flexy_1
SPAM!
How is everyone?
nah you're right and the answer your looking for is they are n00bs with no idea. Half of the topics are useless and the other half are in in the wrong freaking section..noone has any idea how to use the search function either as it appears.
Im going to try hey :D...... hate missing events......work is so gay, currently looking for a job in the retail/fashion industry that goes more further than weekend shit casual work..
Anyone no anyone who needs a hand in a fashion store?. Beauty therapy salon?
hehe doesnt hurt to ask :)
nah you're right and the answer your looking for is they are n00bs with no idea. Half of the topics are useless and the other half are in in the wrong freaking section..noone has any idea.
u so wana be a mod, you know they never make u a mod, seeing the will never make me one as long as sau is around hahaha!
you're spelling and grammar sucks, but no I don't so wanna be a mod lol.
you'd be a dodgy mod rofl...ban's to people left right and centre hahaha.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
