Hello all,
Just thought I'd introduce myself, I'm Adam, came along on Saturday with Mel and stole peoples chairs (next time will bring my own).
I like computers and cars, quite the nerd, but also love the exhaust.
Currently I drive my mums Pre-release/Series 1 Discovery with a 200TDI engine (before they fixed the more obvious faults), getting a new job in a couple of weeks so I'll be looking to get something decent for myself, figured I'd join and look around at what is to be seen.
Dad has a 01 Mustang Cobra SVT sitting in storage somewhere that I get to drive occasionally when he's actually in Brisbane, pretty fun car, but he hates me redlining every gear, parents split up years ago, not much else to me then that.
If anyone has any computer troubles, let me know and I'll see if I can give any tips. As for cars, I know a bit of the technical details that most know, but not much practical experience since I don't exactly get to pull apart any car.
Edit: Oh, also, I believe I'm the only Discovery driver that has a ticket for "Creating Unnecessary Noise", but feel free to point out that being wrong :D
hi welcome... doubt he would see that
Hai guys, my hair is like totaly so hot right now
hahah POOF
I'm too cute to die :(
ahaha poof again
drags tomorrow arvo. and then pull down the 26/30 and send it off (again lol)
is this ur GTR shane? how far away do u love from champions way? i might go to urs to see ur bent rod.. ahaha
i meant ur cars bent rods lol.. seeing im in friggen ipswich *corks shotgun and hides behind bushes* :D
hahah POOF
ahaha poof again
i live ~15 mins from willowbank, basically u have to go past me on the way
u wont see any bent rods at my place mate, that was on the old engine :D
man thats impressive.. yeah ill follow u from willowbank and go to ur place to play with ur bent rod.. :D
i see lee running over with binoculars to see shanes rod :(
hubble telescope..... i will be abel to locate the general vacinity of shanes penis but no one has even really seen or used it before...
surely some scientists have used that telescope before?
and yes, u will be needing the hubble telescope to view my wang, as it is soo big it's orbiting earth as we speak :D
Guest
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
