hi guys..
just finished fitting chris's domeniak FMIC.. ahaha the new just jap ones suck.. i did more custom fitting than fitting and no instructions meant i had to use my well reknown wit.. all in all. was good.
pitty bout having to hack his indiators and seal them up again..
im gonna post a thread up so he can get pics and stuff..
that's why u go jdm or custom :no:
http://www.skylinesaustralia.com/forums/in...=153404&hl=
Dese be da wheels. multifit jobs. boughtem on the cheap. gets what ya pays for I guess. I was just tired of looking at those butt ugly factory rims. The old girl had them on her 01 maxima for 5 freakin years then got the 350z style wheels on her new one. Woooohooo, no more shit factory wheels. So I go and buy a skyline with the same farking wheel. SHEEEEEEESH :no::down:
AAAAAAAAAAA$RRRRRRRRGGGGGGGHHHHHHHHHHHHHHHH
I,ve been rooted up the rissole again. Bling wheels wont clear the front calipers. GRRRRRRRRRRRRR. Any suggestions peeeps. :no::down::ninja::laugh::mad::mad:
You should always listen to uncle Andy
I saw them on the shelf there about a week ago $27 if i remember correctly
ewww slip on! Im trying to teach Noel to be a drift kid.
Noel, you want some 1- 2inch bolt on's, for that phat rim hang look, then some hot looking strech tires.
do it
do it
WTF. If the grind the caliper trick dont work i doubt i will even use spacers. the thought leaves a safety issue cloud over me?
Guest
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
