ahh bugger that noel, and if that is a burn you better turn the gas up a bit more.
yeah its getting there the turbo has finally arrived so will be doing a bit of work on it this weekend.
if you dont speak english i am gonna shit in your helmet
ahah u dnt got enough fibre in ur diet u cant even shit every morning.. hehe
if i find one milescule of feaces flakes in it..! lol
I had dish once....I had to remove them because I could not handle hearing another prepubescent voice go AWWWWWWWWWWWWWW SIK DIIIIIIISH :O
ahaha honda drivers yo
Burn no. mild jab...most definitely. :O
Guest
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
