last dinner, u said std rebuild, just everything got prepped
niggah please, my memory aint that bad :)
i remember that.. i was ther.. i was the guy in blue col.. remember?
u said u went std pistons cause u dnt like slap.. but u like to heat them up and melt them onto ur valves.. :wave:
Oh yeah the guy in blue... You were on my mind all night... :)
No not really... Sorry... Dont remember...
A little.
I expect nothing less, then showing me how the GTR runs when its running
u know how its gonna be :wave:
but nothing is done on forums, kapish?
... mmm wat psi can ur engine take col?
spoken like a true n00b :)
once again you assume and presume far more than is good for one of such tender years. Hard work aint cool bud. but it is a way to make a good living without suckin off mommys tit. Pride i have a plenty, you obviously have none.
You assume im a trust fund baby....take you're own advice, you assume and presume to much or you're getting your information from people who don't know what they're talking about. Last time I checked your parents having money doesn't mean they continually hand it out to you. Maybe I took some of their advice and made some money of my own?? Maybe that doesn't count as I was listening to my parents...clearly, again, not the hardcore thing to do. I wish I was as hardcore as you old timer....my goal in life is to be your age, paying out people, trying to fit in with a young crowd and driving a stock and cheap r33 skyline....again if you don't realise...this is sarcasm.
wat was ur scramble boost set to on the track?
At the drags i ran 15,16,17,18 psi...
The more boost I ran the slower the ET... But the faster the trap speed... Weird...
No scramble boost for me, im not "Fast and Furious"
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
