if u dont mind spending the coin noel, go the haltech. also the boost controller is only $120 for it :(
P.S only downside is for the 33 u gotta get it wired in
Can the haltech not only detect but also manage knock.
See what i mean, theres another partial answer marc. Knock sensor. good to have. Knock control, better to have. What else, dual mapping, timing, spark, air fuel, Just what should a good puda have and be able to do with what it has.
I'm not as familiar with the Haltech but I'll answer where I can.
Dual mapping: PFC - no. Haltech - I think so
Timing/spark, fuel maps: Both are full replacement ECUs so have full control over your fuel and ignition maps
Airflow meter: Haltech allows you to get rid of it by replacing with a MAP sensor. PFC forces you to keep an AFM of some sort, though it allows you to choose between maps for some of the more common swaps (Z32, Q45 etc). You can go the D-Jetro version which lets you go AFM-less but to be honest, unless you're running stupid amounts of horsepower or ridiculously big cams - keep the AFM. They're better at measuring the air and you'll end up with a cleaner, more fuel efficient, nicer ride at the expense of a tiny bit of throttle response at the top end.
Read my last post Matty. i have been around hot cars long enough to know that my mods probably wont stop at that. The puda is an item i only want to buy once.
Unless you're aiming for more than 500hp I would stick with a PFC....the things I mentioned above are just a quick summary of its features from what I remember.....
Saving the money through it pluggin into the standard loom is also a large plus!!
Haltech do make a plugin ECU for the R33, the one I've seen in the E11v2.
In my understanding, the Haltech does retard timing when it detects pinging, which is great. That was pretty much the only thing that I wanted in the PFC that it didn't have.
I made 307rwkW with a PFC without a problem, which would have easily been > 500hp at the crank. Basically, as long as it's capable of running the injectors/coils and recognising the sensors you have, you can make as much power as you want. I dunno how big you can go in the injectors with either ECU before it can't run them quickly enough to fuel properly at idle but I certainly didn't have a problem with it.
i believe the haltech has a wider tuning map, 32x32 i think. also there is built in rev limiter, launch control, nos tunability, its a hell of a lot newer, will be updated as the program/software/hardware progress. it also has a data logging feature. u can purcahse a digital dash for $1600 which shows all ur telementory (sp)
i sold my PFC as soon as i realised how good the haltech was :D
heres the long term deal matt.
current mods (stage one)
fmic, pod filter, turbo back exhaust with hiflow cat, 10 lb boost.
Next stage,
Hiflow turbo, in tank fuel pump, fuel reg, 550 cc injectors, boost control
Stage 3
Stage one cams, Adjust cam gear. Aftermarket plenum.
Stage 4.
forged arse end.
Stage 5. Headwork. titanium valves, stiffer springs. Possibly solid lifters. mild port and polish with manifold match up.
last stage. turbo upgrade.
that is where i will eventually take it. I aim to do it in stages to keep it interesting.
The Maf sensor tend to be a bit lightweight as far as reliability, and is one reason I went with a microtech
Yeah the biggest killer of them afaik is backfiring. The wire is pretty thin and it just breaks. That said, I replaced mine once in the whole time I owned my car, and that was to swap in a bigger one :D
i sold my PFC as soon as i realised how good the haltech was :(
There's no denying the Haltech does a lot more, it just depends on whether you can justify the extra expense. I was more than happy with my PFC though, the results were more than acceptable and cost a lot less than a Haltech, particularly given that, at the time, the only other available plugin was the Wolf3D which I felt didn't suit my needs.
The moment you want to start looking at logging or telemetry :D , you'll need a Haltech/Motec/Autronic etc :)
The moment you want to start looking at logging or telemetry :D , you'll need a Haltech/Motec/Autronic etc :(
As far as extra expense goes marc. what is the better deal. A used pfc that is commanding ridiculous money for reasons that escape me or about another 400 bucks for the better computer with back up available.
I haven't looked at PFC prices lately but they've recently gone out of production, which would likely be pushing up the prices.
Putting myself in your shoes, I'd go the Haltech. It'll do more, you can guarantee it'll expand to suit whatever you do to the car later, there's a plugin version available now so you don't have to cut the loom... and, if the prices are getting pretty similar now, there's no reason not to go for the technically better option, and one that has manufacturer support for the forseeable future.
Doooo eeeeeet
Doooo eeeeeet
My thoughts excactly marc. What i was tyrying to find out tho is, are there any other worthwhile options out there, Link, Wolf etc.
noel jump on the phone to the ogar (dan :D) and get a price for a haltech and a pfc and get his opinion
Opinions are like arseholes shane, everyone has one. I could ask Col, (already making big powah, or sid kid. guru. and gaed knows how many others and come away with different answers. It aint like injectors or a fuel pump. there is so much dark science to these bloody pudas. :D
Unless they've changed a lot in the last 18 months or so, both Link and Wolf (and Microtech etc) tend to be racing ECUs - they will get your car running, but lack some of the things that make a car nice to drive day-to-day. Things like cold start, idle control (when the aircon cuts in, in particular), variable cam timing control etc, and they generally have a lower mapping resolution too.
Guest
    • Good tips, I like it! 😂😂 My wife is a LOT more frugal than me so it's only me we need to worry about! A splurge to her is buying 2 pairs of socks in one visit at Kmart!
    • Haha, the appropriate response to the question "Is this new?" is "I've had this for a while.". With the unspoken small print that a while may be the time since this morning or five years ago   And to be fair I learned that from the best, i.e. my wife. Because it goes both ways.
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
