morning Ladis.....
wow they are really moderating everything we say in here...
who would of thought a little bit of spamming in a spam thread could get so outta hand....
dam man i got hit with random fire even though i wasn't involed... i wanted to be but my account was still mod review from earlier escapades :unsure:
also will you fill my tank with petrolieum distillate and revulcanise my tyres, posthaste?
:P how's about i put HCl Acid in your fuel tank and slash your tires.....i'll get on to that ASAP :unsure:
finding new tyres is the suxxor :unsure:
after a set of 235/40/18's -new or secondhand. No secondhand place has any stock at all atm and newies are about $230-250 ea for cheap ones :P
i've got camber wear on the inside edge of my drivers side (worn smooth on the edges) so really should change them before i drive to rocky.
sure thing.. :P
alright old mate i'll get on to that as soon as i'm done sodimising my self :unsure:
finding new tyres is the suxxor ;)
after a set of 235/40/18's -new or secondhand. No secondhand place has any stock at all atm and newies are about $230-250 ea for cheap ones ;)
isn't there a place near the switch that has good cheap second hand tyres? ask Shane or Noel...
no thats already done terry. (done when the new suspension and caster bushes went in). i actually had three wheel aligns in the last year none of them fixed the problem...
pretty sure i've rang that place - coleman tyres? rang all their branches, plus tyre king at slacks creek.
sofar hankook k104's (what i have atm) are about $250ea
falken ze-329's $229
sava - $249
dunlop sp3000a $289
Goodyear F1 - $325
Pirelli - $310
sava - $249
dunlop sp3000a $289
Goodyear F1 - $325
Pirelli - $310
Rytal Enterprises
Chris Gilligan
0438 328 264
Tell him shane freiberg from kbr sent you.
That's who i get my tyres through, i work with his wife, pat.
i got hankook k104 255x40x17 for $150 each, farking cheap :unsure:
subzero33 put me onto a place in waterford - they have 245/18's for 145ea, or 225/45/18's for 85ea fitted. secondhand of course ,and actually are located just down the road...Hmm... will wait and see what shanes contact can do as i'd prefer newies if i can.
Shane where is he located? can he fit and supply on short notice? (remember i'm moving friday).
Guest
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
