Nah mel got bored to be honest and wasn't feeling a 100% before i came so didn't want to push it
here is the new shiney addition to the engine, I had it redone plus the throttle body as well :)
That is farking schweeet shroom. What did it cost to get that polished.
greddy plenum hey
Guest
