Hey isaac, i just realised my friend Marc bought your suspension :D
Damn his speedy hide
I needed them! One of the shocks on the rear of the R33 is gooooooone
At least Isaac still had the ECU for me...it better fix the problem *shakes fist at car gremlins*
yeah hopefully fixes your 33's woes :glare: failing that i say go with the space shuttle style switch. Piss off all this modern 'active fuel management' how cylinders get 'turned off' you can retrofit it to the skyline :D
Gemma says:
whats with the eh on everything??
Josh says:
i think its a nerd thing?
Josh says:
gemmah!
Gemma says:
deffinately a nerd thing
Josh says:
with out a doubt
Josh says:
but im short, cute and fluffy so it makes it all ok
Gemma says:
ha ha - fluffy
Josh says:
fluffly like a puppy
Gemma says:
what kind of puppy
Josh says:
lassy dog?
Gemma says:
oh i see - so the description should be short, cute, fluffy and heroic?
Josh says:
this is true
rofl's
morning :P
rofl @ Series II in Noels thread...man he's definately going to get defected..his car is so modified..HE RUNS 11PSI EVERYDAY OMGWTFWOW!!!ONE!!1!1 standard cars do that. He cracks me up, but I cbf replying anymore, he doesn't understand.
indeed....thats why he street races with other "fellow racers" yo at teh secret spots yo!! because it's way to risky to go to the track..cops will write down your number plate and fine you when you go to maccas...and he'd be screwed HES RUNNING 11PSI and keep this on the down low but I think he said he has a PFC and maybe hes hollowed his cat out ZOMG!!!ONE111!1!1!SHIFTONE!!! Biggest rebel on here.
Guest
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
