SAu stickers...you got me started now :D
Been trying to get a decent sample for weeks now...first the people you talk to don't actually listen/read what you ask for, so the sample is wrong.
Then you try for another week to get a second sample, which of course is still wrong.
Then you try to actually get a price for these things out of the company, who say "we can't issue a quote until we know how many stickers can be printed per metre of sticker material"
GRRRR hopefully a new sample will be delivered today, all vinyl layered cut-out...then I can see if they suit and then I can get them printed (which I'm sure I'll be waiting a couple more weeks for) :D
Why are businesses so slack regarding the small jobs? I really think its because we are not spending a heap of money. But my argument is if all the small jobs went elsewhere, a business would soon close...
post in the events thread ppl.
this is purly for spamming!!!!!
he he he
:D
just joking do whatever you want :(
30 here i come!!!
see this is where you are not going to make your 30. the main reason being u dont split up your posts. your previous post should have been made up of these individual posts
1)
2)
3)
he he he
4)
:D
5)
just joking do whatever you want :P
6)
30 here i come!!!
Soon you will learn my boy :D
Karen New SAU stickers? or same as the current ones?
They'll be like the original ones, where the AU and the AUSTRALIA will be in silver, and the sticker will be nicely layered (if all goes to plan). They'll be the same size as the existing ones.
The last batch (which is the ones you would have Bryn) were not correct, in that the AUSTRALIA was black and the AU colour looked crap...but they had already been paid for so they had to get used unfortunately.
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
