but in all seriousness you will need somthing that can make the figure at 18psi or under unless a head gasket is part of your plans?
EDIT
You have a forged engine...get a 30307s
already fitted with metal head gasket andy.
Turbo for 300 plus rwkw rb25. Whats the best bang for buck.
Low mount, standard manifold. HKS item. something like a 25/40R or step up to a 28 series turbo.
Hyflows are good, and I wont diss the hyflowed mention as its been a top performer, but atthe end of the days its not a HKS item.
The red R33 from the sunnie coast that was at the dyno day makes 270rwkw on a HKS 25/30 so the above mentioned gives u room to grow.
yeah I didnt read it all ha ha
3037s or GT30 with the .64 housing with a decent whack of boost it should make the power and not be overly laggy
The GT30 can be had with the internal gate too which might interest you
internal gate does indeed interest me. can that turbo be low mounted?
Correct, but nothing quite gives the punch of a nice little HKS item
what peak output do you think is achieavable with the stage 3 hiflows josh. With supporting mods of course.
It can...I can show you some pics if you like...high mount is more convenient but
This is true....But it probably wont quite get to 300rwkw
A GTRS might get close...i didnt know this but apparetntly they are based on a T28 frame not a T25
Whats a stage 3, whos stage 3? specs!!! Stage 3 in 1990 was like a VL hiflow with a t04 wheel. more info bish
Appreciate your input fellas. I am starving and the old girl has gone to sydney for the weekend. I better go buy some food.
A little idea of mine for you to think about.
Has anybody ever thought of going to a largish punchy turbo and using "phase in boost" In other words. Not nos for high end output but nos that is there instantly and just phases out as boost comes on giving you an unbelievably flat power curve for a turbo motor. Been thinkin bout it for a while now. What are your thoughts, back in 30
The maroon R33 at the dyno day makes 270rwkw on a hks 25/30....
Noels car with the headgasket, cooler, ecu, fuel systsem and with the 25/40 should get the 300rwkw pretty easy, in a good rev range. Cams will only sweeten the deal, I might be wrong, it's been a while since ive played with turbos. Using the Maroon R33 as the base, and what ive used in the past as the reason to my madness.
Highflows are all well and good..but at the end of the day, if I was you (and you could afford it), i'd change your turbo. Like Josh and I are saying..either a 25/40..3037s...or practicly anything in the mid to large HKS range are some of the best turbos available. However you can get the same type of turbos in the garrett range, for less money.
Dynos these days!
Guest
