found pics of the old 33 on my phone....i'm so sad :laugh:
My list:
HKS 3037S Turbo
HKS External Wastegate
HKS Stainless Steel Manifold
HKS Triple Plate Clutch
HKS 256' Cams
TRUST Greddy Plenumn
HKS 6x740cc Injectors
Uknown intank fuel pump (large)
Custom Fuel Rail
80mm throttle body
HKS F-CON V Fuel & Ignition ECU
Custom G/force 600x300x100mm Intercooler
HKS Airpod on custom 100mm piping with airflow meter removed
Line Locker & Controller
TRUST Profec A Boost Controller
TRUST Turbo Timer
TECHTOM IIC460 Drag Launch Controller
TRUST 60mm electronic Boost & Exhaust Temp. Warning Guages
Autometer Sport Comp Monster Tacho & Shift Light
Apexi N1 80mm Exhaust
HKS Front Pipe (Turbo to Cat)
Custom Stainless Dump Pipe
Cusco Oil Catch Can
Cusco 1.5way Locking LSD
Veilside Shift Knob
Recaro Recliner Seat with Sabelt Harness
Potenza Suspension
Nismo 400R front bar (needs repair)
Different Skirts, Rear Bar and Drag Style rear wing
17x8 and 17x9" White 5 Spoke Wheels
Slotted Front Brake Rotors and Aftermarket Brake Pads
Rebuilt Gearbox with brand new gear set.
My list:
HKS 3037S Turbo
HKS 256' Cams
Huge Fuel Pump
Custom Fuel Rail
80mm throttle body
TRUST Turbo Timer
Cusco Oil Catch Can
Veilside Shift Knob
Potenza Suspension
Holy shit thats alot of stuff.
Edited by subzeroR33
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
