If hes farkin miles away Andy I am farkin light yearts away. ;)
yes but u see i'll be of the age where i can still enjoy mine, whoever ur son willl be the only one in ur family :)
the cousins have been handy
If my brother the Toyota master technician would actually spin a spanner for me I would be set,,,asshole ha ha
maybe its time for that 2j? :P
P.S theres one for sale in the forums, 6k with decent bolt ons :)
Oh hell yeah, When i get depressed i just go out in the garage and look at my goodys. VROOM! VROOM! :laughing-smiley-014:
What goodies are there???
I spring you advice then you keep me out of the loop
Well I never
Start with this
Genuine Greddy RB25DET intake plenum, imported from nengun by me. Uses standard injectors, or I have a cool injector conversion system that will allow fitment of 14mm injectors. $900 ono - SOLD FineLine pending payment
Nissan genuine RB25DET metal intake manifold gasket $80.00- SOLD FineLine pending payment
RB25DET High Flow 14mm injector fuel rail conversion for RB25DET. Blue anodised billet aluminium with all -6 speedflow fittings. $150- SOLD FineLine pending payment
Aeromotive A1000 -6 Injected Bypass Fuel Pressure, matches the rail with 2 returns from the rail with a central fuel feed to the rail. $220 ono- SOLD FineLine pending payment
Set of 6 new in boxes 650cc low impedance 14mm delphi injectors. 1.1ms stable $450 ono.- SOLD FineLine pending payment
Tomei oil restrictor kit $5- SOLD FineLine pending pa
ohhhhh!, thought you'd never ask. :laughing-smiley-014: how long have you got?
3.532323 minutes
u should see noels new head andy, they've taken to it with a 'c**t scraper' as dan said ;)
Sweet, we will have to compare heads noel :)
What other things are in the engine?
Start with this
I see, Short runners FTL Noel ;) then again you love drag racing so I guess it works! sounds good mate...now sort out the turbo!
3.532323 minutes
Sweet, we will have to compare heads noel ;)
hmmm. bottom end....crank and rods, peened, cryo frozen carck tested, blueprinted and balanced.
OS giken forged slugs oil squirter notched.
farkin awesome port job on the head including chamber modification and cc matched
On order. Hot cams, adjusto gears. stronger valve springs. Himount manifold, 30/40 garret.
On the shelf as well. q45 afm, q45 throttle body
waiting to be pulled out of car. pro comp power fc with launch control and laptop compatible.
Nice!
Sound like a twin for mine ;) noice
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
