Ewww
""This is what happened to me just then
My mother walked in on me jerking off - she didn't freak out or anything like that. But what she did do was insist that for her peace of mind, that she demonstrates how to place a condom on properly.
So she went to her room and returned with one, sat down beside me on my bed, and kind of pressed on my stomach motioning me to lean back. I did as she asked as she proceeded to open the condom. I figured that this was way too weird but I'll just put it on fast and get it over with.
Well, I was wrong. It became apparent that she had every intention of putting it on me herself. I just watched as she rolled my foreskin back, and telling me that this was proper because otherwise the condom could slip off. Then she started to slip it on. She had to flip it over because she had it the wrong way, but she very easily had it run down my dick and to the base.
Well, that was all it took, that one downward motion. I was cumming in the condom as I was apologising, implying that it was part her fault cause she came in at a bad time.
She just smiled and patted my stomach and said something like "Well, at least you didnt make a mess".
She got up and left at this point, leaving me to wonder WTF just happened""
Edited by Silver_R34_GT-T
Ewww
read that before
i think it is bullshit...
well i hope so any way...it is very disturbing.. and gross
Guest
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
