This message is for the old fart (Noel)
Mate i cant make it to willowbank this wednesday, somethings come up and ill be in Kingaroy for the night on Wednesday... :(
But Ill get her ready for the next one, pitty its so close to winter nats tho as it will be uber busy...
i might need protecting too andy.. will you hold me ? :P
Ever so tenderly
p.s. i put a myspace friend request through 3 days ago.. where is the love :(
Sif I get on myspace more than once a week
Sux to be you
that..is hot!
Specs? Release date?
yeah specs on that thing, it looks sexy
erm... here are two articles...
http://www.dpccars.com/photos/05-13-07page-Audi-RS5.htm
http://www.drive.com.au/Editorial/ArticleD...ArticleID=25397
hows the ceffie going donkey_punch? (ive see it from time to time when i drive past dans place)
Guest
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
