nah 1.5 JZ
quick pass that one nearly as quick as shane's hybrid. pppffffffttt
there is no flow bench testing proving the 1j head is better then the 2jz head.
Why build a 1.5j for the hell of it? You'd only do it if:
a) your 1jz blew up
b) you had a high end 1jz head already built with a shagged bottom
I've done the cost's, starting from nothing its cheaper to just use a 2jz.
Edited by Nismo_Boy
josh i hope these cars ur bringing to the dyno day have got some decent power :)
One is a stock R32 with open pipes, the other is a "close too" 2.7lt, built head, motec, GT-RS turbos ect. We'll see, I wana tinker with timming and fuel to pop 400rwkw, my mate is being a pussy and just wants to roll on 18psi and pump gas. I say ban him!
mmm noise & flames, hell yeah thats some half decent hp :)
Only thing holding it back is bigger injectors.. :D
Nah should be good, I reckon it'll do 320 - 350rwkw on the day. Would be nice to bump the boost more and have a play to make a magic 400.. but it's not to be maybe i'll keep talking about it and convince him :)
a) your 1jz blew up
People build em for the response as well, not just for outright power.
if its power then 2 jz all the way....stuff opening it either. :)
lol what's it with people and under sizing their injectors? :)
soo ur saying the 2.5ltr 1j head would be more responsive than the 3ltr 2j? hows that work? lol :)
its like putting a rb20 head on an rb25....it flows less HP, as in the inlets etc are smalled....but from that it prevides better response...its like putting a smaller turbo on your car....but more expensive....there are a few other details that it changes too
come on shane..
Guest
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
