lol what's it with people and under sizing their injectors? :)
Car was built for reliable everyday horse power, not out right power. Your right though, while doing it why not just go bigger for later on.
Either way, a new set are coming
People build em for the response as well, not just for outright power.
if its power then 2 jz all the way....stuff opening it either. :)
I love toyota, and everything they have to offer, in fact i used to want a 1.5j. but go drive a 2jz 6 speed and then tell me they are not a responsive motor. I'm saying cost vs cost its cheaper and more easy to go 2jz, unless you have a big dollar 1jz head already, or you are doing some of the work your self
Edited by Nismo_Boy
I am not having a winge stig man, just lookin out for me fellow stigs.
i'm not talking about you....but thanks for the heads up...i've seen much worse posted on here...but that was in the old days *cough* Charly *cough* I think the mods will be fine with what i've said. I just don't like someone claiming to be police stating things that are clearly wrong.
IMO the QLD Police would find his comments offensive. He has said that officers decide the severity of the fine based on the attitude of the driver and not the law they have broken. Thats not how it is supposed to be done. He also advised that we loosen dump pipe bolts to get the same effect as a sceamer..erm no and it's also illegal. Then he says all mods are illlegal unlees engineer's approve them. That is clearly wrong and even the basic Transport modification guide says so.
as far as i'm concerned I doubt he's even a Police Officer and if he is, I fear he's one of the ones that do fine people incorrectly making us go through the court process to have it cleared.
What's happening Bitchez?!?!?! >_<
:wave:
hey hey :wave:
missing ur anna much?
come down to aarons dyno day ! only like, 4 SAU members signed up so far.. disappointingly small. especially if we get outnumbers by Boost Cruising kiddies =\
i'd go...if i had a running car :P
Hey you...
we been having discussions...yay!!11one!!!11 fun fun.
whats you been doin girly?
Nuffin ..
Bored shitless :(
Trying to pass time at work and havn't been on here for ages :P sooooooooooo .. thought I'd pop by to say Hello!
"Hello!" *waves*
haha
>_<
hey hey :wave:
:wave:
Yesh :(
Missing her soooooo much!! Mainly because I know she's so far away haha BOOO!!
How have you been mister?
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
