hi josh..
how u doing buddy..
bring it to dyno day..
should i run the 180 on dyno day..?
shane spot me biatch
If you want it I will bring it and you can take it, otherwise I cant be assed having it roll around in the car.
I'm good though, been looking at jobs trying to place it al together.
Yes, run the 180sex
hey joshwa :teehee:
ripped out the std fuel lines on sat, and dropped the fuel tank. i'm thinkin nows a good time to replace the diff, all sub-frame bushes and adjustable arms...
what size lines u going?
Yeah might as replace it all nowski
Yes, run the 180sex
hmm no cash but ill watch.
ok ill take the cat.. ill make her fit!... notthing like 1 anglgrinder disc and duct tape cant fix. ahaha.
i remember you calling me dodgy for using an angle grinder :teehee:
replacing ur diff..?
uh how come ur replacing ur mech diff shaney poo.?
she'll be right. how worn are ur bushes.. u gonna use bushes or alluminum plates..?
yepo, goin 1.5 up back and 1 way up front, gotta open the rear one up anyway caus the seals leaking
bushes are leaking :D replacing the subframe ones with alloy ones, and the rest with the whiteline ones, getting it all from sydneykid
plus i'll need replace the diff's sometime, as i dont think they'll last too long with 750bhp and many limiter launches :teehee:
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
