A saw a mighty boy for sale, it says 4wd turbo.
So i had a closer look and year it was fully evo running gear...
The owner says its stock as a rock and runs a 55 lap round QR sprint... Thats quick as...
But when you car weighs less than 600kg's i guess thats expected... :)
Would be fun!
Well im off to my "State of Origin" lunchen, then onto the XXXX brewary and then on to the game to enjoy front row seats on the 50 metre line and then back to XXXX keg room to finish the night off...
Enjoy your day people... Ill talk to you all tomorrow night when Im sober again... :)
Bring me back free beer.
Yeh used Du Point acrylic. My brother painted the car, he needs more practice before he did an out side job, just been doing mates car for around 8 months.
how 'durable' is acrylic compared to 2pack do you know?
i need my car done, and wanna get it in midnight purple/pearle, same as my engine bay. any idea when he wants to do 'outside' jobs and what he'd charge? i can rub it back too, soo all i need is some1 to spray it
Acrylic is easier to spray and make look right, 2pack is thicker and harder to spray and get looking nice. I'd say due to the 2pack being thicker it would be more durable, however you do enough coats of acrylic it will be fine, plus with enough clear it'll look deep.
He would do it now, but I doubt you would be happy. He still has a lot to learn thats all.
Normally it's around $500 plus paint for it to be sprayed.. Depends weather you supply your own cutters/polish (some people prefer certain products). You get what you pay for eh
give me a heads up when u reckon he's up to scratch :)
i'll hit u up for more info then
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
