why oh why would u buy a short shifter..
stupid... anyone want mine.. i pulled it out of the 180 last night.. bloody thing had to remove the top of the box off... and getting the forward to bolts was a mission.. that and the bloody circlip..
and why would u buy a shifter that meshes ur gears too quick before the syncros could spin off the gear oil and make it crunch.. stupid idea to me.
SR20 Short shift kit for sale $100 pm me lol..
obvioulsy different to a skyline. like i said before, i put a C's short shifter in my old 33, no crunching issues, obvioulsy youve got a half shagged box :thumbsup:
siff have standard syncros....dog box and learn to rev match, its the only way.
HI5 :sorcerer:
by rev match u mean to be able to smash it through the gears without the clutch? well thats what i mean by rev match ;)
my cams have arrived
picsandspecsorban
Just sounds like a shit gearbox to me
My short shifter works flawlessly Cs FTW
werd...had a short shifter in the 33...no probs.
HI5 :sorcerer:
Indeed I do mean that....more so rev match with a cross cut gear set (dog box) as its a biatch with no syncros. No real point rev matching on a car with syncros other than high rev downshifting to prevent compression lock ups or to challenge yourself if your clutch ever goes lol.
why would you want to see a pic of a cam lol, it is a stick with lumps on it ha ha
spose it also being for an rb2....nah i wont do that again :P
caus its a new part, every 1 wants to see new parts :domokun:
P.S watcha have for tea, left over brains? :P
sif go cross cut/helical gears when u get a dog box, its like saying u want aids that wont kill you :domokun:
os giken or ppg gearset ftw...dog engagement boxes are a biatch though, i'd hate to have one in a regular street car....way way to much effort. Some form of Syncros really are your friend.
Guest
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
