WOOT, finally got Vista installed...had to delete a fricking file through dos to get it to work!!!
So you finaly got it done, i bet your not as proud as the taxi driver was last night about his skidies
hahahahaha, most humerous event evar!!! He did well off the lights, he had the tyres smoking!!
Guest
