Please do, it keeps me on my toes...
Plus you know I could never get angry with you Shane... Your like water and Im a ducks back... :D
scweet, licence to thrill :P
I heard the rifle fire, but im yet to see if the shot was on target...
if i was half cut i'd call that some wise jibberish, too bad i havnt had a drink since friday :P
EDIT:- left half a reply out :(
BTW
I do not condone your statements...
I do not agree with you threads...
I do not support your whoring addiction...
But I still love you :P In a non-ghey way...
and thats abo for covering ur ass :P
Thats gotta be signature worthy Shane... :P
If you choose to use it, Ill just edit it out once I grow tired of it... :D
pfft sif i'd waste space in my sig with a post of urs :P
P.S change dans dry sump thread title to "Monday night tea party"
Nice suggestion, but no... That may cut too deep...
How about I make you a moderator for 3 seconds so you can do it and then you can cop the wrath of a big man which a large tool in his hands... :P
edit: I meant large spanner, like a 32mm ring and open ended... A big tool... Get it...
Nice suggestion, but no... That make cut too deep...
i'm down with that :P
Guest
