BTW with that summons, I thought there was such a time limit on them, like speeding fines, 28days to pay sorta crap, not 1 year on wtf thats a joke
There is a time limit, if after 28 days you havent paid the ticket or filled it in to take it to court it roll's onto SPERS as you no longer have a choice. Neither of those options where taken..
Year later I get this
Edited by Nismo_Boy
Long story short this letter shouldn't have came... They were told Media or drop the ticket over a year ago
Sounds like they are taking the Court (and media) option. They always take that long to respond with action when dealing with fines that have had complaints/letters sent in with regard to matters such as that. Case and point my fines with that cop who was off duty, who acted like a tool and learnt a lesson for being ghey.
When you send a letter contesting the fine or the like, it's taken that you are taking teh court option, usually they send you another letter saying pay the fine though....although that is the pleading guilty part of the summons.
And as per normal I will continue to make it hard for them. The thing is... The fine was handed to Steve and he was told to deal with it, I don't think there were any correspondence in regards to it.
It should have went to SPERS...
Nothing was sent like that.. It was more like my verson of events on paper the ticket and a verbal pull ya f**king head out of your ass and fix this shit
yeah, oh well....when you get your license back you'll be on your opens and you'd only lose 3 points for that anyway...who cares...fight it for fun or just pay the fine, either way it wont really affect you.
true date of issue was on my opens anyway
Interesting twist:
The summons was served wrong, technicality number one. Only a small one but mistake none the less.
The paper work is wrong, the paper work appears to be in another car when in fact it was the fine in Darrans Charade
*goes back to finding all the paper work/research*
Guest
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
