yo..
please educate my friend.. im trying to convince him/her that a 1jz engine is a far better choice than a RB25 neo/RB26DETT..
for say a 180/silvia or a project car..
stock for stock or modified.. im done trying to convince him...
if ur doing the conversion y only use a 1j? a 2j would seem more logical
The other thing you could try is to remove the return line from the reg and turn on the ignition. If there is not enough pressure to bypass the reg, then you will never start it.
Then check spark. I can test your coil packs, PTU and injectors with an ignition tester I have but you should make sure you are getting power to everything first. Chuck a noid light on the injectors and see if they pulse. The Z32 AFM won't work on the standard ECU as it has a different resolution, but I'm not 100% on whether it will stop it from running completely. If you get stuck......I'll happily buy the car from you for $1
i can 100% say that the car will crank/idle with a z32 on a stock ecu. I know this caus when i was swapping johns parts out we tried this :rolleyes:
farken ace!
autocad just sent me this sweet message:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\AutoCAD 2006\acad.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for mroe information
Guest
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
