Ok i finally got the top off, what a f**ken challenge that was. I really needed some GIGANTOR'S. Now the pump, you say pull it upwards, but it doesnt want to move. How much force is needed, i dont want to break anything.
A bit of force is required. You need to reach down into the tank, grab it by the stem and pull up hard. Ask Shane, he can help with the stem grab and hard pull up. Lots of practice makes perfect.
I just got my car back from Peter Woodward, he installed the injectors but thanks to you know who you are, the bent rail gave him hell, he also setup a water methenol injection system that he is trialing in 3 other cars at the moment, it made 360rwhp on his dyno :D I will post up the chart when I get the chance, probably sat arvo. He tells me there is more in it but i wanted my car back because it is just too damn cold to ride the bike to Carol Park like I have been for the last 2 days, I thought I had frost bite this morning BRrrrrr.
I'm STOKED for both reasons !!!!1!!!
im gonna sue, caus that there is defamation...:)
ooooor u could just unclip the cradle and lift it out, but hey its upto you :banana:
maybe u shoulda just stayed with the non-bent one :banana:
sounds good terry :D
Ok jackpot fellas, i finally got the bastard out what an operation. Its easy now when you know what to expect.
Ok now the problem is what type of fuel pump to put in. It looks like a nismo pump i just pulled out.
Should i go Bosch 023, Sard, Tomei or Nismo. I just want to keep in mind about future mods which will be aiming for around 400rwkw.
im gonna sue, caus that there is defamation...:laugh:
It's only defamation if people care about you Shane. You need friends first.
Plus I'm only stating facts. I knew you would be able to help him get it out. You are 'THA MAN'
Guest
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
