im honest. but my GTiR working days are over.. i hope to never work on one again.. lol
does it crank round..? starter crank over.
GTiR SR are the same as every other SR but larger flowing oil pump solid lifters. its basically the RB26 of SRs. except it runs a dizzy lol.
let us know its symptoms and we can pinpoint it.
got RACQ out and after the dick head finished his wise cracks about "his 5L this, his 5L that" proceeded to tell us well he cant fix cause its an imported piece of shit... but will have a look
he took out the spark plug thats easy to get to and it was drenched in fuel so basically when cranking the motor its pouring in fuel but no bang...
Markimak - please help! Im sure you could come out of the closet to work on one last gtir!!!
Farkin hot rod builders. :D My little black bitch ran away and left me for the local rod builder cos he can insert a 3 and 1/2 inch pipe. Unfaithful little s**t. After all i did for her. :laughing-smiley-014:
ok u said it was running shit.. so sounds like electrical problem. and having no spark to ignite fuel. im gonna throw up. battery/alternator/dizzy/leads.
sounds like ther is not enough power to run the spark so u need to find if its prior to the dizzy..
i could have a look see.. whats this bout me in a closest.. what has josh told u lol.
check charge rate. battery. dizzy. leads. ignitor.
the engine is pretty much bullet proof. the car is pretty bullet proof (apart from box) so i doubt it would be a mechanical problem. but u need to tell us more..
My vote goes on the rear view mirror not being correctly aligned. Man that shit can throw everything off.
Skyline is basiclly sold now... :D
Got a car yard to put an offer on it, so now I have a week to try and sell it for more however I dont think it will as everyone are tyre kickers these days...
Im asking a grand more that the car yard has offered, and its gonna cost a grand to put it through road worthys and mod plates...
So im not holding my breath...
i reckon its the left hand windscreen wiper being 20mm higher than the right hand windscreen wiper
You don't want to buy a 33GTR off me when you sell yours do you? It's only $3k more.
Guest
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
