It's my pick because rather than cutting costs by blending into polyalphaolefin base stock for its motor oil, Red Line Oil only uses superior poly ester-based products—resulting in lubricants that are extremely stable at high temperatures while providing superior film strength at lower viscosities where more power can be produced.
Motor oil.
Red Line synthetic motor oils are a superior strength oil, designed to provide the highest degree of protection and cleanliness for your engine. Red Line lubricants contain polyol ester base stocks, the only lubricants which can withstand the tremendous heat of modern jet engines, which makes our motor oil a necessity to properly lubricate a hot running engine or a turbocharger. More importantly, Red Line motor oils can significantly reduce engine wear, which means a longer useful life for your engine. Unlike other oils that break-down quickly, thus having to be changed at small intervals, Red Line has superior long-drain capabilities. Read about how Red Line synthetic oils have been shown to last 40,000 kms in field tests.
Race oil.
Red Line has a complete line of race oils (5W up to 70W) that work under the demanding conditions of high-performance driving. Red Line Race Oils have gained a reputation as the ultimate racing lubricant. Marketers of other lubricants unsuccessfully claim to be “as good as Red Lineâ€. Our lubricants are used by teams who understand that improved performance and equipment durability is the key to winning. Our race oils are made with the most thermally stable synthetic base stocks available and provide the best high-temperature lubrication and a higher film strength than any petroleum or synthetic marketed. Red Line Race Oils provide more power than an oil of similar viscosity, while providing much more protection. Each reduction in viscosity grade allows 1–2% more power.
Redline can explain it better.
Basically protects engine better. Make more power. Oil is more thermally stable. Only oil that can lubricate hot metal.
Redline are the only oil manufacturer that can PRINT that they are better than all others on the market because they can actually prove it.
now THATS's what i call a good post, it certainly doesnt belong in whoretown :sleep:
Also....ask R33_Racer why he uses Redline in his track car? I'm sure he'll tell you it's because it's a far superior product.
...either that or because his dad tells him to lol.
....But if you ask his dad, then, he would definately say that....definately.
they were using motul lemans (up until the last race)...
...they may be changing, whow knows
so bitch, what's 12ltrs of this fang-dangled redline gonna cost me?
Guest
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
