if you run a greddy plenum it will open up the top end and it shouldnt nose over...probably need a good exhaust manifold too (6boost). Our gt30 .82 rear went to 320rwkws without water injection and it pulled all the way to 8k redline. Remove all possible restrictions in the bolt ons and you can run the smaller puffers further to the edge without losing power.
Im up to 332rwkw now on 21psi and still have stock cams...
So a goal of 350rwkw (which to be honest is too much for a daily driven car) is easily achieved from the Garrett GT30R also know as the GT30/40...
Im at 21psi by 4000rpm btw, so its quite streetable, just farking stupid round town when it comes onto boost and jumps sideways... :unsure:
So i turn the boost controler down to 16psi where it makes just on 280rwkw and thats far easier to handle round town... :O
Im at 21psi by 4000rpm btw, so its quite streetable, just farking stupid round town when it comes onto boost and jumps sideways... :O
So i turn the boost controler down to 16psi where it makes just on 280rwkw and thats far easier to handle round town... :P
thats promising. i said noel's car will break the 400rwkw mark, and if ur results are anything to go by, he should do it fairly comfortably :unsure:
all noel's has to do, is pick up 69kw from 4psi more boost, cams & massive headwork, piece of piss i reckon
Easy.
if my bitsa can can 490rwhp/365rwkw on a td06-25g with t78 wheels on 1.5bar (3800rpm) Noel will piss it in
Fkn A doggie, shouldn't be a problem. Andy got 306rwkw on 18psi i'd like to see them bump it up to 22 or so and see what he can get. He doesn't think it'll be much of a difference but with the new fuel pump and shiz he shouldn't be running out of fuel like last time. I'm trying to convince him to go back to chiptorque, best tune we ever had was from them.
theres heaps of stuff on youtube, theres a clib with arabs drifting a Carrera GT and a McLaren Mercedes SLR....
I too am watching youtube clips...
cept i'm reminiscing so mine are in the form of
http://www.youtube.com/watch?v=wor-Z4SyWCg
http://www.youtube.com/watch?v=Qmve365Ti1k
かわいらしい さくら - MISS KITTEH! says:
haha and I wasn't a fan of human nature
except for one track which was very BSB/nsync
Josh says:
some one will think im queer when they see this history
bahahah it will just confirm rumours
Josh says:
they're only true when im drunk
Josh says:
lol
z so i'd find you at the beat then?
hehe
Josh says:
they sell cheap drinks
Josh says:
quiet u
Guest
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
