Its a movie set in Spartan times, I just watched it last night and Im impressed, its been a while since I have seen a movie where I was totally engrossed but I couldnt not watch its awesome. **warning scenes of gratutious violence** 10 outa 10 from me
how farked are 32 gtr boots? why would nissan make them so farking small :nyaanyaa:
Cos ashun women are smaller than euro babes hence they are easier to abduckt and fit in the boot of a 32. :laughing-smiley-014:
this is what im gonna have to do now. will need to cut the floor around the cell & tank so i can drop the tank down enough to get the correct fall for the fuel filling pipe from the std filling location in the guard. Also need atleast 22" height for the dry sump tank
haha.. yeah.. u doing ur inner or outer shane. stuff using nissan though.. get some repco ones and a seperator.. tkaes 10mins per outside corner to do on AE corollas.. hehe :sorcerer:
yes, i shoulda kept the boat, aka 33 :thumbsup:
learn quick..
wtf u talking bout? :nyaanyaa:
no space saver shane..
will prolly have it mounted under the car after the cell goes in
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
