cant fit the tank in the boot without cutting the boot floor. The tank is 22" tall (3gal) and theres only a max of 20.5" from the base of the wheel well. However the std fuel tank runs right up underneath where the wheel well is, so theres no simple cut and shut way to do it :P
ill be round soon with the 9 inch, i love cutting shit up. You should have seen my mates drop top datto ute after i got to it with a angle grinder.
haha yeh i love my 9 inch too, gets alot of use at my place lol
the thing is, y need to run a fuel cell to fit the dry sump tank in the boot in a 32. 33 boots are deep enough u can put the tank anywhere
your gtr is neva gonna be finished
wanna put ur money where ur mouth is?
im sticking to my guns that it'll be ready early december :P
awesome if you get it done in time
but why rush it now its not like you want to cut any corners on the final stages.
Who are you going to be using for tuning??
heh, im not cutting corners, i've budgeted it out and it's come up as early december being the completion date
that's a tough one. Prolly mark from godzilla, seeing as he tune's his and theo's cars, and im going drag racing, so it seems the logical one. Also i need advice on suspension setup and diff's, and he'd know.
quick around circuits. how many drag car's have they setup?
personally, i didnt like the reception i got when i asked them what they knew about a crank trigger disk setup with the autronic.
my ultimate goal with this car is a 9, but that's not gonna happen for a year or 2 i reckon, main issue being the box
doesnt giant do a low 10 in circut setup, im sure they would know a fairbit about setting a car up to quick at the drags.
yeh they've run a 10.2, but i wouldnt get the support at a test session with cnj as i could with godzilla.
dunno, theres still a few months before it comes time to pick, so we'll see
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
