yeh they've run a 10.2, but i wouldnt get the support at a test session with cnj as i could with godzilla.
dunno, theres still a few months before it comes time to pick, so we'll see
yeah, i undestand where your coming from. It's easier to replicate someone elses setup and reap the benefits of their R&D dollars. I would do the same thing if i was in your position.
so ben, how far along are u with this 3ltr?
decided how far ur going with it? as in hp and rpm wise?
ive got dan tracking down a r32 25de head from his importer.
im just waiting a bit for the rest of it though cause i have a job interview on tuesday with mlc
y a 25 head???
yeh 350 shouldnt be too hard with a gt35r, and 7000rpm is nice and safe :wave:
y a 25 head???
i want a R32 rb25de head cause i have confirmed all my stuff like cams injectors and exhoust manifold will bolt to it and bring costs down alot.
all that would be left is machine work, forged pistons and rods and dans labour
^^^^^^^^Ok its on the 26th next weekend, its a show, shine and swap meet. Its held at Pine Rivers Park at Strathpine. I think thats on the main drag going out to Petrie. Might be Gympie Rd.
It was posted here but it was closed for some unknown reason.
Edited by subzeroR33
Hello ladies,
Question for the day,
Looking at getting some HKS Cams/cam gears - should I do it with my set up
Hopefully i just picked up a HKS Low mount and trust ext. gate to go with my Biago turbo I am getting through Murnane cant remember much about the turbo exactly was initially going the smaller internally gated one but now with the new manifold I will be more than likely doing what slide was selling as a Biago T40 if you can remember what that was.
Fairly decent sized turbo so I’m guessing there will be a little lag to contend with
Current state: PFC, FMIC, full Exhaust,
Adding: Turbo, Manifold, Gate, 740cc Injectors, 040 Pump,
Considering: Cams / Cam Gears
If need be I will call murnane to get the details of the turbo but as far as I know he basicly will customise the turbo to application
And im asking in here cause the forced induction forum is full of wankers and is too messy to navigate/get an answer and i have come to value the oppinions of the regulars of the wasteland
Cheers,
Dan
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
