Hello ladies,
Question for the day,
Looking at getting some HKS Cams/cam gears - should I do it with my set up
Hopefully i just picked up a HKS Low mount and trust ext. gate to go with my Biago turbo I am getting through Murnane cant remember much about the turbo exactly was initially going the smaller internally gated one but now with the new manifold I will be more than likely doing what slide was selling as a Biago T40 if you can remember what that was.
Fairly decent sized turbo so I’m guessing there will be a little lag to contend with
Current state: PFC, FMIC, full Exhaust,
Adding: Turbo, Manifold, Gate, 740cc Injectors, 040 Pump,
Considering: Cams / Cam Gears
If need be I will call murnane to get the details of the turbo but as far as I know he basicly will customise the turbo to application
And im asking in here cause the forced induction forum is full of wankers and is too messy to navigate/get an answer and i have come to value the oppinions of the regulars of the wasteland
Cheers,
Dan
sarp fool
well basically with the 25 head u dont have that greater pick of cam's, as the std hydraulic lifter setup can only go so far in lift. (9.XXmm i think it is)
saying that, i'd prolly go with something around the 250-260deg and 8.5-9.15mm lift.
looking on greenline, tomei only do a poncam of 256deg duration & 8.50mm lift. hks do 256deg 8.8lift or a 260deg 9.0lift.
depends how big that turbo is, id go the bigger of the cams
however, if u were going take the head off and get it refreshed, u can easily get it converted to a solid lifter setup, then u can run a gtr cam, which u'd have a hell of a lot more option with cam selection
sarp fool
Weak, I had 272's.
Speaking of which they just came out, some soild lifters went in and bigger cams again. f**k I should buy that car back lol.
shotgun (if they are suitable) :P
this is what i have sitting in my nengun shopping cart:
HKS - Camshafts - Nissan
Nissan ECR33 RB25DET -97/8 INLET, Duration 256. Lift 8.8mm (For NVCS engines, Not suitable for NEO Straight 6)
2202-RN172 - AU $ 378.77
Nissan ECR33 RB25DET -97/8 EXHAUST, Duration 264. Lift 9.0mm (For NVCS engines, Not suitable for NEO Straight 6)
2202-RN175AU $ 378.77
Would that be on the money?
also will it sound cool? :)
whats Noel got?
also I was gonna go with HKS injectors just to be a complete brand fag, I have not heard of many people running them any opinions on them? i seem to mainly hear people useing nismo/sard
^^^^^^^^Ok its on the 26th next weekend, its a show, shine and swap meet. Its held at Pine Rivers Park at Strathpine. I think thats on the main drag going out to Petrie. Might be Gympie Rd.
It was posted here but it was closed for some unknown reason.
That little tree symbol at the centre of the map is what Whereis gave me as Pine rivers park, what time does it start?
Thats farkin Jambo weekend dude. Who's the klutz that lined it up against that?
Not sure between 9-11am. I think you would be safe to see a few things.
shotgun (if they are suitable) :D
also will it sound cool? :P
whats Noel got?
Fark yeah that is cheap for HKS cams, whats the delivery fee around $800 to ur door :) .
those prices are delivered!!! not bad eh
this is my shopping cart at the moment:
HKS - Cam Pulley - Duralumin
Nissan RB26DETT/RB25DE(T) All Duralum / Slide, For inlet side (except for NVCS engine).
22004-AN001 AU $ 148.87
Nissan RB26DETT/RB25DE(T)/ All Duralum Slide, For exhaust side
22004-AN002 AU $ 148.87
2202-RN172 AU $ 378.77
2202-RN175 AU $ 378.77
HKS - Fine Tune Timing Belt
Nissan RB20DET, RB25DET, RB26DETT
24999-AN001 AU $ 139.55
HKS - Fuel Injectors
HKS 740cc Side Fed injectors ( Red )
1402-RN009 AU $ 793.53
Splitfire - Super Direct Di ignition system
Nissan - Skyline - ECR33 - Series 1 - 8/93-1/95
SF-DIS-001 AU $ 471.41
Order Total AU $ 2,459.76
Delivered to Brisbane 4127
now just to roll a couple of granny's next thursday and I will be set
Fark yeah thats a nice list :D . I am lining up a set of Tomei cams but i might look at the HKS as they are only a little dearer but they have a better name, i spose you get what you pay for.
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
