For those who were going to the Japanese swap meet thing that was going to be on Sunday;
CLASSIC JAPANESE SHOW & SHINE
POSTPONED!
Due to some excellent rainfall the location for the show is waterlogged and the event will now be held on the 14th of October go to CJSS Page
http://www.zcarclubq.org.au/events/cjss07.html
gtr bearings mate....its a secret haha...not really but ill explain later or atleast to dan, see if his bloke chilton knows about it or can even do it.
I know i dont have to help you, but if and when im free, instead of sitting at home doing jack i could be helping or doing something productive which will not only aid you in your gtr quest but help expand my skills, knowledge and maybe a little money on the side.
cheers for the heads up :wave:
hmm ok, i'm intruiged
that's true. well theres a fair bit of welding that needs doing. cage, seam welding (stitching), boot modification
i've now got my hands on a copy of the design guidlines so i have all the requirments i/we need to meet for it all, which entail lets me get mod plates for the work, so it can be easily done ourselves
awesome...well for the cage im assuming that andra has a rule book like cams and in it they would have various designs that would comply to their specs and you can build one and then get it checked and approved. Thats how we did it for our cage, picked one design out of the cams book and built it and got it complied.
I guess same goes for the design guidelines from tpt. Which should take any guess work out of it all. I know one of the blokes who is a customer at mercury who runs a 32gtr for drag racing has a half cage in his, so even still could copy his one which im sure is andra spec.
storey, is i changed my oil ;) and took off my front bumper so i could trim some more plastic outa the front, and thought i would trry and fit my washer bottle,...
:thumbsup: still no washer bottle
how much oil exactly should be put in the rb25s ;)
i ask, becuase yesterday we changed my brothers oil, and he got 4 litres
today we did mine and i got just under 5
Edited by Silver_R34_GT-T
Guest
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
