mineral oil marki, best stuff for diff's apparantly :D
apparently.. yeah heard bout that too.. was gonna go castrol as im a castrol man. but heard some shit with castrol and redline in cuscos.. so i got 2.5L of penrite coming.. short notice shit.. 80w-140 should be fine.. will change it every 10kms.. :)
any other suggestions guys
no but im serious was told that i should use not synthetic on cusco diffs.. as it shudders with synthetic..
meh penrite it is unless i can find some redline cheap.
The shuddering can be corrected with an additive that redline also sells.
You should only need 1.5L so 2 x 1L bottles is all that is required. $60 and you're sailing!
howdy all,
week end is over :P
got myself a nismo short shifter and a Z32 today and marki - :)
shal be good getting it all in, im over the hks manifold idea now after talking with murnane again on sat they reckon slap the biago internally gates sucker on there and tune, cause it should keep me happy for a while
its solved guys, basically we were discussing if my mate with a gts4, could simply remove the altessa pump fuse to allow him to slide corners and do burnouts...
was intersting and went gor a while
Redline at any price is cheap you tightarse.
im tight.. pretty sure students dont go out and buy 700 diffs like that..
y not buy some of that cusco oil then? 90 bucks for the bottle isnt it?
wher is this from.. im keen... found kaaz oil..
think ill go to autobarn tomorrow. wher do u find the oil u speak of for $60
howdy all,
week end is over :(
got myself a nismo short shifter and a Z32 today and marki - :D
haha great. how much u pay.. yeah i dnt need the Z32 yet.. think ill keep my 160kwish for a while.
nice eh.. ther is a N-S mounted 4G63 in a EVOIX in japan. designed for drift.. no more AWD.. kinda pointless i think
got it of 666DAN for a great price, getting his gauges too when he gets a chance to pull em out. he said you were trying to get it but i had already given the word... timing my friend!
if i only had a doller for every time i saw a deal on these forums im usually too slow to act.
Guest
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
