hmm white skyline right now on channel 7. went off road and hit a pole killing driver.... its got teh police doing a full check over it seeing why it went of teh road... very interesting
nighto shane.. hope the sump adapter goes in well :(
i could do it myself, but i dont have a drill press/mill, so it looks like im gonna have to take it somewhere *picks up phone* :D
i couldnt handle having to work shifts of varying hours, it'd shit me to tears
Guest
