Shane: Noel and I were chatting about the projects and time taken to complete them tonight. It all boils down to one thing - PREPARATION.
If you start out blind and just think I want this, and just add bits until you think you have it right, you will always be disappointed with the hack of a job at the end of the day and you will always spend twice as much and it will take twice as long.
Before any great project you have to sit down and write out your goal. Write down a list of EVERY item you think would be needed to achieve that goal. Then take it to someone who knows what they're on about (not some cash junkie workshop that only wants to sell you parts that look bling or might be bits he has to get rid of coz they been on the shelf for a while). Once you have all the information you need, take your list to another place and get a second opinion. If there are differences in opinion, ask why, then go somewhere else reputable until you get two well known and good quality workshops to agree on what it will take to achieve your goal. Then you proceed with a plan of attack to get everything done.
Once you have broken it down and know what you need and how to go about it, all the legalities etc. , then you will have a smooth operation.
Either that or just FRIGGIN ASK ME IN THE FIRST PLACE!!!!!!
Then you wouldn't have to spend so much money on crap you didn't need.
Yeah BOI!!!
lol ill walk on him.
lol!!
hows my fist sound..??
I dunno, hows a criminal record, and an expensive civil suit sound to you?? Honestly marki, we've been through this before. Get over it.
dnt worry its not just me i knw of others that arnt too fond of u. its just the world as u say
What, you know a few people on this forum who aren't fond of me? How genuinely sad this makes me. I know people who think the same of you, does it really matter at the end of the day? No, not really, unless your seriously vested in making everyone on this forum like you. I don't know what your social status is Marki, but I don't depend on this forum for friends.
DAN, whats the total?
Dunno mate, the lift pump was $130 but the filler I won't know until it arrives. The express air freight from USA he said would only be $50 and will take 3-5 days. But not sure on the actual cost of the item. Just fix me up when it get in.
K brudda?
lol!!
What, you know a few people on this forum who aren't fond of me? How genuinely sad this makes me. I know people who think the same of you, does it really matter at the end of the day? No, not really, unless your seriously vested making everyone on this forum like you. I don't know what your social status is Marki, but I don't depend on this forum for friends.
I like you mate.
And that's all that matters.
Yeah BOI!!!
this sounds familar...oh that's right u've told me this before :)
well u know where it's heading now, plus i dont want a half assed job parts & fitment wise.
K brudda?
k, i'll transfer 200 and i'll fix u up the rest when the stuff comes in (pm bank details mk)
P.S dan that fuel system price doesnt include the shit i've fooked up on lol, that's the price for all the pump,s filters, lines, fittings, tank, injectors, fuel rail etc etc
Pajero 3.0lt V6 is just way too quick. Like OMG u need overdrive off to pass people quick. f**k me, watch out M1 IM BACK
patty go alrite eh? mite have to give u a run on teh M1 on my pink pushy :sorcerer:
Guest
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
