pathetic....sparco...not for me....dont look good enough for me to get....bride all the way....or recaro or just jap specials.
man winding up the torsion bar will make it shittier at off road stuff...but i guess your not using it for that so it'll be ok.
wtf you worried about weight for....your a skinny little prick mark.
i weigh over 80kg at the moment.. eat much work out more thats my saying.. been lazy lately though.. stupid study and sleep..
why i dnt like weight.. heavy cars are gay.. less weight less to push around less load on driveline.. i dnt want to break parts..
yeah but my understanding that sparco are light and this is cheap i want light and cheap.. so it ticks my boxes.. and i get my 2f2f credit for using ther endorsed products
Tell ARB not to lift torsion bars when they do lift kits then lol... Yeh it's budget, if anything it will make it WORSE on road. Debaitable how much offroad, as you said it's not used for offroading anyway
good point...what i was thinking
oh and pg2you big boy.
uhuh ok
fark aye, im only like 68kg lol
i weigh 75 no matter what i do or eat or not do and not eat or go to the gym...doesnt change...stupid body.
....and yes no matter how much sex i get either....stupid body..
sex makes u lean lol..
how much protein u eat..
i was always taught work out as much as u can till ur bod aches then work more.. recover in a few days and repeat... its like doing laps around a track.. go hard or go home.. then warm down
boob job hey???
Squizz did it hey???
U sure???
I noticed it the other week and it just had the word 'boobs' in there, slipped inbetween a few other things, then i noticed the rest poped up.
I thought you had just sliped it in for "shits and giggles"...
YEAH I KNOW WHAT YOU MEAN, BUT I USED TO GO TO THE GYM...AND DIDNT DO ANYTHING....FARKEN AUTOCAD...better.
boob job hey???
U sure???
bahahaha....yeah....i had boobs in there, then Squizz went and changed my name to start with..under request....but he decided to change a few other things as well.....so i kept some of his changes ...not all of them though....some were a bit too far but thats ok.
Nice >_<
Hey Josh, who said 6 litre V8's are not fuel friendlly...
I got it down to 9.0l per 100 this afternoon after refueling on the high way and then jumping staright on the highway and poped it on cruise :)
I took a photo with my phone, it said range left 820km... I wish you could actually get 800km's per tank... :)
Arhhh the pleasures of getting more than 250km per tank...
Nice >_<
U drive like a nanna!!
The new 6.0lts arent a bad motor though
Yeah im happy with it now its got a few km's on the clock (3000kms), as it was a bit tight when new...
I reckon it will loosen up a bit more towards 10,000km's and might use even less fuel once properlly run in...
Very happy with its roll on performance. Does not suffer from heat soak like turbo charged cars...
That said tho, its no where near as fast as the skyline in terms of how quicklly it picks up speed, nor any where near as fun to drive like you stole it...
You can have any beer you like, as long as its a Corona!
On that note im gonna pinch a lime from the tree and have a beer.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
