Yeh it's not really worth it, but it's some funny shit. They're mostly crazy monster girls that beat the shit outta the guy or other girl before they sodomise them with sharp implements :D
I've put a ban on myself... i'm not watching any more until I find my favourite one... it's gotta be on one of these discs :D
Is that the dry humping one!
yes exactly...makes you realise how good real pron is.
so anyone knw wher to get season 5 in englsih manga?
no stop asking.
or search www.isohunt.com
and get the torrent.
$1000 eh? :D each? ....... :D
I want these rims.....
they are volk GTCs tim i can find a nice set in 18 for around 2600-3500 dependin on colour
they are my fav ;)
I am so bored... I am so bored... B-O-R-D... I mean B-O-R-E-D
get a job.. or talk to me on msn ;)
bullshit, ur black u can strip and car in 5mins
ahaha.. im doin a turbo on the S14 now.. hopefully the head gasket is fine :)
bahaha....how about i swap you for a geniune set of 6 gtr r32 rims...with tyres.... :D
but seriously...dont sell em for less then 3500
yeah ill get that huge off you soon....just make sure you get in there nice and deep boy.
yeah 3500 is lowest ill sell them nismos for!!!..
oh well 8 mins is up my pasta should be done.. now for the sauce ;)
Nice choice of rim Tim. hotness. i havent found a fav of mine...which is why i would stick with a dorifto tek.
actually i have now...the Work XT7 mmmm nioce.
Sif dry humping old man. Anyway after last night i'd dry hump anything, I had a blast!11
bahahaha
I laughed then
so did i.
i dnt drive no stagea.. bahaha
not funny
uh-huh. do you like it when it's got a story line or you prefer it to cut to the chase?
I laughed then
Don't laugh at my perverted self :D
:D it wasn't you... he was cuter :D
JK wubs you ;)
Guest
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
