its not an air sound unfortunately, and its not detonation cause it is happening at 4000rpm no matter how far the car is boosted, whether it be still under negative vaccum or positive pressure.
ohh if its only at 4000rpm.. CA18s have this problem too.. it ended up being the connecting rod lol.. 2months later it died.. :)
my money is on the bottom end.. sorry rohan.
I guess this will make sense will i've met Dan
he is a big bloke but.. hes a gentle giant
Morning everyone. :)
I really want my car back.... being ferried around by my girlfriend in her XR5 Turbo is nice, but I want to hit the gas and have to take my foot off to stop the wheels spinning!!! I miss skids too.....
stupid RBs :action-smiley-069:
ohh if its only at 4000rpm.. CA18s have this problem too.. it ended up being the connecting rod lol.. 2months later it died.. :yucky:
lets hope we are all wrong.
AFAIK they are.
Depends on 42 spec come to think of it. The american's have some weird speced turbos. You sure it wasn't a SP42 or something along the lines of that, Shane
Edited by Nismo_Boy
farken hell i brought a C spanner of ns.com and send the money weeks ago and i ask him wher the hell is it.. he says he never recieved it.. his account details check with the ones i sent to..
"mate ive been into my bank 4 times now and they have ABSOLUTELY no information for me because nothing has come through
you tell me what im ment to do?
no money has come through
Ive been selling items online for the past 3yrs and have sold hundreds of things and never had this problem and there is nothing more I can do about it as the problem isnt from my end there is no indication of the money coming through at all
only thing my bank said I could do is for you to scan the bank statement and take it to my bank but that wont help any because they have no control of the funds that arent in their databases
so maybe get your bank to contact westpac with my details and find where the problem is because I am powerless as nothing has come through yet
Michael "
i call bullshit. its only $30 so i cbs doin small claims or something like that. any recommendations
Michael "
who is the seller?
AFAIK they are.
im over lookin at turbo's. lol
ill let dan make the decision, then if it dont make the hp i want, it's his fault :yucky:
Michael "
get ur bnk to look into it. i had a similar problem a few yrs back, u ahve to sort it out through ur bank.
who is the seller?
SELLER
so go to my bank give them my details and ask why they didnt put the money into this guys account lol..
Yeah but that still has to be built.
then build it. ill give u a hand
Guest
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
