Where is Rohan
I need to get up him for not letting me get up beside him on the way home from Noels the other night...and I forgot to do it via SMS
eh...??? i was waiting but you never came up beside cept when i turned off....on the onramp i was only in fourth accelerating...and the next time was 5th...but its ok to get beaten by a 20.
bahahaha :) git down bish
I thought you would have waited...you know since I was right behind you 400m before the double lanes...but noooooo you went off prematurely :D
this dude is selling surge tank setup for $300 excluding the pump
I already have a tank lines and 044 how much would it cost to do the fittlings like the one pictured or would i be better off buying the surge and lines of this guy and sell my current lines and tank? Im guessing I could get $150ish for what I already have.
who does speedflow lines and fittings at a decent price?
im waiting for him to come and answer it for me :) any other ideas welcome!!!
also shane what are the possibilities / complications of running an aftermarket rb26 fuel rail and injector on my 25 I dont want to have to forkout for injectors again once it is 26 time. PFC running it.
Guest
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
