oh yeha.....touche....stupid shane and him having to go home....bastard.
below me
this dude is selling surge tank setup for $300 excluding the pump
I already have a tank lines and 044 how much would it cost to do the fittlings like the one pictured or would i be better off buying the surge and lines of this guy and sell my current lines and tank? Im guessing I could get $150ish for what I already have.
who does speedflow lines and fittings at a decent price?
so what is it u want to use from that setup he's selling? by the sounds of it u already have the stuff u need...
dont buy speedflow or the like (i use Earl's) in aus, as its all waaaaay too expensive. i have bought all my gear from the states (summitracing.com) however i may have found a supplier up my way who can beat the us prices...
i hope ur pockets are deep if u wanna play with braide >_<
shanef will know....where is the bish when you need him.
here now :D
im waiting for him to come and answer it for me :) any other ideas welcome!!!
also shane what are the possibilities / complications of running an aftermarket rb26 fuel rail and injector on my 25 I dont want to have to forkout for injectors again once it is 26 time. PFC running it.
problems i can see are
1) fuel rail bolt locations (rb25 side feed, rb26 top feed, rails have differing bolt locations on the plenums)
2) Injector driver in ecu/resister pack. (rb25 high impedence, rb26 low impedence, hence the resister pack on rb26's)
3) o-ring on 'bottom' of injector. the one that seats in the plenum. i've got a feeling theres some difference there too
Afternoon weirdos. I'm going to check out a car this afternoon... man am I pissing myself with excitement!!1
is said car going to sound like this?... ASS ASS ASS ASS ASS
:spank:
annananananananananananananananananananananannananananananan
hi
gl with the car!
fark you then miss ignorant :D
ok so could you do the lines in the picture for less than $200 bucks new? appprox? im guesing not even close aye
those lines and fittings look hawt and will ad 11kwatw
depends where they go to under the car...
PICSORBAN BISH
I haven't been to see it yet so these two are just from what he's given me and they're only little...
hi
gl with the car!
lizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizz
izzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzl
zzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzli
zlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzlizzliz
hi :D
dan, u have a 33 right? them lines in that pic are to suit a 32, so the length's wont be right for ur car (u need them longer) plus a few of the fittings would have to be changed
fark you then miss ignorant >_<
f**k off.
hi :D
hey darlin, how are you?
I'm really good :D I started my beauty stuff so i'm on my way to finally having my own little career. I've already had a few randoms volunteer for waxing :sorcerer:
How's you? How's your car going I haven't heard about it in ages.
he said it includes everything you need to install im guessing this all just links up to the stocko lines under the car.
from what i can tell it will be everything bar the nos setup in the photo
hahaha good work!!!
I'm ok! But of a shitty mood today. Actually... a feral mood! My head is spinning, my shoulders ache, I'm waiting on results from a medical test before the place I wanna work at will issue me with an offer. My car is a little fooked.... that sums it up!
I saw pics of the car you're looking at! I'm excited!
its ok, i dont want to be associated with a pair of silvia owning females anyway >_<
Sweet as. I usually don't like to hang with mummies boys who collect garden ornaments for fun either :D
hahaha good work!!!
oh shit hey... *anna yells penis at liz* hahahah see I knew that'd cheer you up :spank:
I hope your test results come back with something good, are you looking at moving on from your job?
Yeh the car is a little dinged up and the engine is buggered but it's all good. That's what I was after haha
shit didnt even think of that!
Guest
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
