dad lives over here 3 weeks of every month, and he thought it would e good for me to come over for 2 weeks and stay in his apartment for something to do
so here i am :D
yo shane hypotheticly speaking,
if you had an R32 GTST that had an R33rb26 rwd conversion done its matched up to a 25 box and hardwired DLink ecu
Now take a basicly stock R33 GTST and swap the two engines between the cars loom and all - so the 32 had the 25 from the 33 and the 33 had the 26 from the 32
what are the problems/obsticles to overcome in doing this?
reason being my friend is looking at selling his freshly built car and if i can get the cash together he is considering the posibility of an engine swap
(he has decided to wear a skirt and buy a house)
you can ask me i am doing a conversion atm.....
yeah shane would blab on about r33's and rb26's...and 32's and curse each one....maybe.
but yeah as i said above....if you change everything, then just placement of items and radiator etc, and tailshaft, gearbox mount are the only bits i can think of, but then shane may think of something else.....oh you may need to make room for the different style plenum off the 26, fuel lines.....fuel pump, dump pipes...should change straight off the other car.
space wise should be fine as its a big single conversion
at the moment all i can think of is radiator and dump but they should be easy
how do the engine mounts go?
engine mounts are the same...as all the block castings are the same...as with the rb30.
but probably drive shaft...gearbox mount maybe....radiator.....space to do it...every thing else should match up...
what do you mean by driveshaft?
and the gearbox should be fine cause the 32 has a rb25box in it that th 26 is matched up with the clutch has been changed from pull to push or whatever it is
ahh touche.....if they have the same box in them it wont be a prob...but if the 26 had a 26 box, then the length of the shaft might have changed....i think you need to get a different yoke ...i will find out soon.
only problem i can see is in the loom/hard wired ecu form the rb26 car.
you have 2 options:
a) get someone who knows what they are doing and have wired in a link beofre to un-wire the ecu and transfer it into the other car
or
b) swap looms with the engines
option b would be heaps easier in my opinion, as you could do that urself pretty much, and u know its going to work (well ull have more of a chance of it working :P)
everything else will just swap straight over and bolt up :D
Guest
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
