sif you'd own a porshe anyway....Euro crape in shane's werds. :D
bahaha
dam...might be easier stealing it off a wrecker....if you can find one..... :)
Porshe sounds like a VW replica :laughing-smiley-014: I'd own a Porsche though :)
Siff buy used euro parts.. Waste of time, they'll be all shagged
Edited by Nismo_Boy
Farkit!!!! finally get all the niggly crap out of the road and now the freakin cat is causing a restriction. Bye cat. :D
wait for it, wait for it....i told you so :)
nope :)
well not enough to do much damage anyway
phew! all is good then.
i've always wanted to know liz, u know how the sr block is alloy? if u overheat it wont the block warp aswell as the head?
wait for it, wait for it....i told you so ;)
dude, that was one of my major concerns with the sr! I've always wanted to know the answer! :(
so yeah, i dunno!!!!
dude, that was one of my major concerns with the sr! I've always wanted to know the answer! ;)
hmm yeah. i've never heard of any doing that, but then again i dont have much to do with them.
if they are anything like the rb heads, they warp, bend & become porous (sp) when overheated!
Depends on the grade of the alloy, you might find it warps less the a cast iron block....but it is less resistant to shock...depends on the mixes of metals they use and how they were cooled etc..
amazing i do rememeber stuff from uni.... ;)
so dont over heated them.... ;)
rohen u mummy's girl, what time we heading this arvo?
"a"
meat you at milton macs at like 5:30 - 6.
comprende?
soon enough itll get to you and you'll be compelled to fix it ;)
All part of stage 2. After the bathroom reno when the flywheel and pulleys get done I'll have the rack bushes remanufactured.
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
