If a shop does some work and, because of their work or choice of parts, it fails, it should be up to them to sort it out. In your case, they chose the hose and didn't make any effort to shield it from the heat that would quite obviously come from the exhaust/turbo side of an engine... they should at the very least replace it with something more suitable, and preferably repair any damage caused by the hose melting.
Thanks :unsure:
Yay go Karen!!
Hang on... MOTHER??? *runs*
baaaaahahaha :P
Anna i reckon you would mother Andy a bit...
I mean you made hello kitty toast for me that night and i was just joking...
I reckon he could order up a feast when your around... Are you a clean freak like me...? I mean to u seek out house work just to do something sometimes...?
VOTE Anna as a mini Karen???
Hahaha was wondering if you'd pick that up... left it there just for you :P
lol i feel speciallllllllll >_<
Shane... your motor is upside down...
Keep it in that position for too long and the pistons will fall out... :P
And into my block...
but they simply wont fit into ur measly 2.5ltr gts-t :laugh:
i put it up to show off the adapter plate...seeing as i've been talking about it for over a month :laugh:
Alot of the time she does! Other times she tells me to jump!
Fixed... :laugh:
lmfao
I was admiring your adapter plate...
I do want to drag you at willowbank one day tho...
What times are you expecting for your fat, over weight, slow reving 3 litre...?
10's with the track set-up, and 9's when it gets setup for the drags...
Andy i hope she is in a good mood today i dont want to get you inot trouble...
I just got my best mate into trouble by telling his girlfriend he is cheating on her... Opps... :laugh:
I dont like guys (even if they are mates) who step on women like their dirt...
I do, yes. I wonder if he would ever have clean dry clothes if I wasn't around. Also, I think he would sleep in the same sheets all year round. And not throw out undies whey they CLEARLY have holes in them. Or keep a fresh stock of filters for clean water. It's fun though, I like to look after my boy! Cos he looks after me!
Oh sif! If you ask, I do!
You were checking out Shane's flange??? >_<
:laugh: *shudders* :laugh:
I do, yes.
Ohhhh where were you when i was looking for a house maid...?
Fun, fun you say... I just do it to prevent bordom...
Looks after you hey??? Ummm (Homer simpson voice) "Explain How"
Afternoon all
bucks Party was great, a lot of us knew the stripper so was funny as.
God i hate rego time especially when you know that within the rego period you are getting a new car!!!!!!!!!
Its ok! I wont be in trouble!
Good call mate! I would do the same
Guest
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
