Whoretown - Now Interest Free
Squizz
well guys decided on the next family car for my mum..
http://www.j-spec.com.au/list/11321
it will be a 2JZ bahaha... TRC for her.. and ill put a R154 in at a later date and take it off her hands in a few years.. looks good. looking at under 14k for a aristo on road that will smoke ya commo whores
of course it would its a farken 3lt turbo numb nuts....it will smoke most stock cars ...in a straight line.
bah....
ill let that slide dan..
oh well what u all think of letting my mother drive it lol.. i rekon its a good family car... creature comforts. grade 4... and cheap...
2JZ no shit!
bahahah...
yesh the gold painted silver badges....that people steal....i think..
man i would find something that you didnt have to service every 5000k for a family car..something N/A.
seems more the right thing.
Not the fake gold lexus badges?
sure its an option
bahahah...
hmm some of u guys are game only servicing every 5000kms.. i do mine every 3000kms.. just cause my driving is a lil closer to limiter and more often up ther.
nope mums getting an aristo and its gonna be a 2JZ..
wats ur oil like when u change it though mark?
silly question i spose though, seeing as u wont know how much it's detteriated unles su get it tested...
black. silly boy..
i knw its prob a bit much but i do track it. i go get temps over 100 oil degrees and i rather be safe than sorry.
Guest
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
    • Yeah sure, which messenger app is it?
    • would you like to be added to the messenger group?
    • Found some from 2009. The lobster bends were smoothed out on the inside with minimal gaps (perhaps 2mm) where the silicone joiners were used.
    • And if you have to drive it in a civilised (or excessively woke) US state, find a way to register and insure it in a redneck state, so you can roll coal in it without worrying about legalities.
