i wont be coming
the chalkf**king rocks $3 coronas
My suggestion..Broadway for dinner (its on Logan road behind the gabba corner of Balaclava street) then wander up to the chalk for cheap drinks and a band (3 minute walk)
pre warning as of last friday they upped the price to a horriffic $4 so we are boycotting and heading to the aussie nat for kronenburg's
My new oil cooler set up is teh porn signature FTW
my old tune by those who shall remain nameless was not teh porn
AFR dipping below 8:1 in the midrange(sensor only reads to 8:1) and overly advanced timing in the top end (30 degrees advanced)
despite that was still making 260rwkw so I am expecting some good things when done
in case you miss it in the other thread Marki
And since I am bored today Marki here is some maths for you
a 300rwkw r33 GTST gives a rwhp to pounds ratio of 0.13461
a 240rwkw s13 gives a rwhp to punds ratio of 0.1197 which is signficantly slower
to give a s13 a similar power to weight it would actualy need 270rwkw giving a rwhp to pound ratio of 0.13467
oh and my 300rwkw skyline has a rwhp to pounds ratio of 0.146
maths is not your friend Marki
*shakes head*
maths is my friend. ive seen many examples of silvia vs higherpower 300kw cars..take for instance a R8 297.. care to explain how a 200kw SR silvia pulls away from them.? anyway i got 4.667 and 5 th of the car weight based on 1200kg and 1400kg.. which is giving the skyline benifit of the doubt.. :P
*shakes head*
maths is my friend. ive seen many examples of silvia vs higherpower 300kw cars..take for instance a R8 297.. care to explain how a 200kw SR silvia pulls away from them.? anyway i got 4.667 and 5 th of the car weight based on 1200kg and 1400kg.. which is giving the skyline benifit of the doubt.. :O
1220 is the s13s dry weight 1360 is the R33 dry weight
you are ministry of misinformation
in any case bring your 240rwkw i wll be waiting :O
in any case bring your 240rwkw i wll be waiting :P
challenge accepted.. shall i tell my tuner to limit it to 240kw..? a nice fat torque line would be noice.
INCORRECT.. S13 is 1170kg and the 180sx is 1220..
lol marki, i think thats a challenge....
i believe it is..
My RB56 will dominate all!
u dnt count.. i need nawss no this will do... no lets make it two.. and dan i need it by tonight.!!!
but in all seriousness. the new car is costing too much so i will have power next year :D
but we shall go drags together :)
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
