one day. mite be comin on the crawl later in the nite with 2 of her cousins (who i mite add are farking gorgous aswell)
they are probably ginger kids..cause only a ginger kid would be seen with a ginger kid
and sif not come you whined that you wanted steak...and here it is
yeah you better cause i am thinking of not going atm....cause it looks kinda boring cuase will be no single chickys coming along!!! there's no hope!!!
did i mention i have new mags and that you want to see them tonight
i aint paying to cook me own farkin steak, come on
plus i'll be in carole park at 6 at the laser cutter, no chance of getting home, changing n then getting back into brissy before dinner.
u better go bish! we can run a muck, no womenz style :D
new mags eh, picsorban!
pubs are full of single chicks loser :D
sure why not make ur already extremely overwight skyline even MORE overweight :)
lol.. ur learning GTRs are a bit heavy too
well u dont become wold leader by crusin in a 34 thats for sure ;)
:P
no u need a partially built GTR
neva planned on becomin world leader, but out of curiosity what does a world leader drive? airforce one? i dont think its a 4 wheeled bike :)
like said partially built GTR
Morning Whores.... :D
hiya... :(
dude im bringing one for all u guys to share.. now settle
bogan ones with missing teeth highschool is where ther at andy
been there done that, high school girls are stupid and care too much about what dolly says you should and shouldnt do! You need some one who doesnt give a crap and goes for gold ha ha
ANDY http://www.j-spec.com.au/list/11361
a R154 will slot nicely in that!!!
I can get those boxes hella cheap too :D
i knw aye. but damn so tight and pure. haha
hmm how cheap..? im listening..?? think we can put a 6spd getrag on it..? they handle a shit load of power from the JZA80
Guest
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
