only retards use apexi turbo's :D
and only even retarded retards crack exhaust housings on apexi turbo's :D
yeah the whole driving of your car can lead to problems like that
much safer in the backyard :(
RS4's are the bomb :(
On a totally different subject I found this on Ebay.. I'd like to know where this guy got his prices from..
R32 GTS-T
I payed $17000 for it and since then I put on the carbon bonnet - $1300, the custom made front mount intercooler - $2600, custom exhaust - $1100, major service completed at about 120000k's consisting of new timing belt and upgraded to HKS adjustable timing gears and high volume fuel pump - $5500, had pioneer splits, pioneer dual sub box, amp and MP3 head unit fitted - $3800, adjustable bilstein suspension - $3500, BRAND NEW HP DESIGN 19" deep dish rims and TOYO's best tyres fitted - $4200. Blew a turbo gasket a couple of months ago and had that replaced and some other stuff done while they were doing that anyways - $2600.
much safer in the backyard :)
sif even have a turbo charger :)
i want a turboed supra :(
as do i.......:(
I want a supercharged M3.
word on the street was u had aids...words on the street now is u certainly do have aids
me too! pure hawtness
R32 GTS-T
I know where he got the prices...starts with P ends with dtor
30/both/china town
Hi Melvin.
oi fochers. whats the power delivery on the supras like? a tt rz im talkin (94 model, so no vvti)
270rwkw, 264 9.0 cams, std turbo's. 2nd gear useless?
Depends how the go peddle is used and what tires are on it.
The one I drove just had an exhaust and FMIC, was lots of fun for a stock car. Smooth power, punchy down low.
interesting.
are the stockers reliable? i.e what are the chances of turbo wheel departing and entering cat/motor
comparable to the skylines?
Shits on skylines.
nothing is reliable. Chance's are the same as any other factory made ceramic turbo.
pics??
should be safe on 13psi
You can tickle 1.1 - 1.2bar out of them from time to time if your nice, but thats not an everyday thing.
Guest
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
