You're ghostin' us, motherf**ker. I don't care who you are back in the world, you give away our position one more time, I'll bleed ya, real quiet. Leave ya here. Got that?
Billy. Billy! The other day, I was going down on my girlfriend, I said to her, "Jeez you got a big pussy. Jeez you got a big pussy." She said, "Why did you say that twice?" I said, "I didn't."
Edited by r33_racer
ok todays flavour:
Fully built by ATS (Allstar Tuning Systems) Brand new never run
- RB25/30 Conversion
- Block done 20thou, Crack Tested, Acid Dipped and a few more things i cant remember (to be added)
- ACL Pistons
- Spool Rods
- ARP Bolts
- Tomei Cam Gear
- Ported and Polished Head
- Tomei Cams (Intake and Exhaust 256)
- Custom Fuel Rail
- 680cc Denso Injectors - SOLD
- Bosch 044 Pump
- NGK Iridium Plugs
- Cometic Metal Head Gasket
- Oil Cooler and Relocation Kit
- Splitfire Coils
- Cusco Catch Can
- New Valve Springs / Seals
- Greddy Plenum
exchange my motor +6k
For 6 k with all the above mentioned its a farkin bargain. Spend another few hundred and as a proviso on the sale get the jolly green giant to tear it down for inspection and reassemble it.
6k + his motor (say 2k) = 8k...but yeh tear it down for sure
Guest
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
