Whoretown - Now Interest Free
Squizz
paint touchup is finished on my car but i cant get it till 5.30. GRRRRRR
wtf whys that?
Screw dailys if i had one i wouldnt drive it anyway why drive a crap car when you have a good one? Just make the one you have good for all occasions!
Yeah cause it does not have the AYC, the AYC diff is a bit weak over 250awkw...i wont be taking it beyond that anyhow as the rods arent that safe beyond there either (except for the 500hp stock one i saw the other day :wave: WTF )
to do that u've gotta compromise on it in too many areas
yeh thats it, apparantly costs a fair few k to change them over too....theres always 1 that breaks the boundaries lol
id love to turn u into a euro whore
Too bloody dear
wtf whys that?
Like i said though, I dont care about playing with the big boys so ciomprimise is fine
other night put a t piece into my mates CA powered silvia got it to go up to about 10 psi but amything over it cuts the power im guessing its the factory computers "boost cut" whats the cheapest/easiest way to combat this problem?
Look what i found when searching for a new avatar
What's with the posting of pics of me, eh? I look like a little hog in a white shirt. Not cool.
Oh and with all this talk about 'my car, my car, my car'... well MY car truly shits on all your cars. Even yours noel. You know it.
snip the wire? (dont ask which one though lol)
ASS ASS ASS ASS :wave:
whens it gettin to rivers' place?
WALK WALK WALK WALK
Not sure yet, the guy I bought it off is being really good with letting me keep it at his place til I can arrange transportation.
they fail in old cars,
mine is fine....i had it regased though...i love it
WALK WALK WALK WALK
I have car trailer and 4wd let me know if you need help...i have next week off.
boost restriction. std ecus on sils have boost cut. or perhaps its fuel cut either way its gay..
get a fuel pump or FCD...
... i hear HKS make a good lil unit..
in regards to shane wanting u to cut a wire..
the wire u want to cut is orange and black.
im serious this is the boost sensor wire into the back of the ecu. it is wire 40-50 one of them on the pin out.. far out how would i knw this off the top of my head :wave:
red wire? blue wire? watch out fellas you'll blow up the building if you don't get it right! Then thousands of peoples' lives will be on your blood stained hands. How tragic.
are you going to be in/around said building?
Quit whoring and do some work.
Speaking of which, you are babysitting my 2 kids tonight. Thanks again for offering and I'll see you about 6.30 :D
/randomness
having cake....mmm cake
supply me with beer and a hooker and i'll be there at 6:30 :)
Guest
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
